Texas Instruments TI-30X IIS Battery Replacement
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: step 1, image 3 of 3
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
    Ask FixBot
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: step 2, image 1 of 2 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: step 2, image 2 of 2
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
    Ask FixBot
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: step 3, image 3 of 3
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
    Ask FixBot
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 1 of 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 2 of 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: step 4, image 3 of 3
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
    Ask FixBot
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: step 5, image 1 of 1
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
    Ask FixBot
20 other people completed this guide.
Ryan
515 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 39
Past 30 Days: 112
All Time: 37,454
