This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Tools
High Content Rubbing Alcohol$12.99
Introduction
Go to step 1 ↓Targeted bridging of the testpoint requires precision, but enables reliable restoration of access at the system level. After a successful reset and proper reassembly, the smartphone will restart in the regular setup assistant.
After removing the back panel, release all screws securing the upper plastic frame above the motherboard and carefully remove the cover. Note: Ensure that no flex cables or clips are torn when lifting the frame.
Place the removed plastic cover with the antenna foil neatly onto the work mat and disconnect the battery connector from the PCB using a plastic spudger. Note: A de-energized logic board prevents irreparable short circuits during subsequent measurement and bridging work.
Locate the specific hardware test point contact on the motherboard next to the shield. Note: Comparing with the board layout of the Galaxy A26 ensures that the correct measurement point is contacted against ground.
Place one tip of the fine metal tweezers on the test point contact and the other tip on the nearest ground shield (shielding/shielding plate). Note: Hold the tweezers steady and secure to avoid damaging adjacent SMD resistors.
Connect the USB-C cable to the smartphone quickly while continuing to hold the test point shorted to ground. Note: As soon as the PC Device Manager registers the emergency port (e.g., COM port/bootrom), the tweezers can be carefully removed.
Perform the reset via the service software on the computer, disconnect the data cable, and reinsert the motherboard cover and screws precisely. Note: Reconnect the battery firmly to the motherboard before closing the device and check the boot behavior before adhering the back cover.
Work through the steps in reverse order to reassemble your device.
