Up to 20% off select tools
Tesla Keyfob Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
152
All Time:
1,099
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Tesla Keyfob Battery Replacement, Remove the battery cover: step 1, image 1 of 2 Tesla Keyfob Battery Replacement, Remove the battery cover: step 1, image 2 of 2
      • Lever up the battery cover by using a small screwdriver or similar device.
      • Do not attempt to open the side of the keyfob that contains the key ring. The "front" of the fob is the removable portion.
      Ask FixBot
    2. Tesla Keyfob Battery Replacement, Remove the battery: step 2, image 1 of 3 Tesla Keyfob Battery Replacement, Remove the battery: step 2, image 2 of 3 Tesla Keyfob Battery Replacement, Remove the battery: step 2, image 3 of 3
      • Using the same lever device used to remove the cover, lever out the battery where indicated.
      • Remove the battery
      • Replace the battery with your replacement CR2032 in the same manner as it was removed.
      Ask FixBot
    3. Tesla Keyfob Battery Replacement, Reassemble the Keyfob: step 3, image 1 of 1
      • Install the cover once the battery has been inserted.
      Ask FixBot
And that’s it! Go for a drive!
Author
with
Michael Snively
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 152
All Time: 1,099
