Tent Pole Shock Cord Replacement
    1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: step 1, image 1 of 1
      • Remove the old shock cord from the tent poles.
      Ask FixBot
    2. Tent Pole Shock Cord Replacement: step 2, image 1 of 1
      • Measure and cut the string to the length of one tent pole piece.
      • Be sure to leave enough room on each end for knots.
      Ask FixBot
    3. Tent Pole Shock Cord Replacement: step 3, image 1 of 1
      • Tie the string to the end of the shock cord.
      Ask FixBot
    4. Tent Pole Shock Cord Replacement: step 4, image 1 of 2 Tent Pole Shock Cord Replacement: step 4, image 2 of 2
      • Use your hands or pliers to flatten out a bobby pin.
      • Any long, thin, metal object will work to help feed the string and cord through the poles.
      Ask FixBot
    5. Tent Pole Shock Cord Replacement: step 5, image 1 of 1
      • Tie the string around the end of the bobby pin.
      • The string and bobby pin will be used to feed the shock cord through the pole.
      Ask FixBot
    6. Tent Pole Shock Cord Replacement: step 6, image 1 of 3 Tent Pole Shock Cord Replacement: step 6, image 2 of 3 Tent Pole Shock Cord Replacement: step 6, image 3 of 3
      • Drop the bobby pin and string through the tent pole pieces one by one.
      • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
      Ask FixBot
    7. Tent Pole Shock Cord Replacement: step 7, image 1 of 2 Tent Pole Shock Cord Replacement: step 7, image 2 of 2
      • Once the last piece has been threaded, untie or cut the string from the shock cord.
      • Tie a large knot against the right end of the last piece.
      • The knot must be large enough to prevent the shock cord from slipping through the pole.
      Ask FixBot
    8. Tent Pole Shock Cord Replacement: step 8, image 1 of 2 Tent Pole Shock Cord Replacement: step 8, image 2 of 2
      • Connect the tent poles.
      Ask FixBot
    9. Tent Pole Shock Cord Replacement: step 9, image 1 of 1
      • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
      • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
      Ask FixBot
    10. Tent Pole Shock Cord Replacement: step 10, image 1 of 2 Tent Pole Shock Cord Replacement: step 10, image 2 of 2
      • Tie a large knot around the tent pole end piece.
      • Fit the end piece into the left end of the first pole.
      • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
      Ask FixBot
    11. Tent Pole Shock Cord Replacement: step 11, image 1 of 1
      • Disconnect the pole pieces.
      • Fold the pieces to test the shock cord tension.
      • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
      Ask FixBot
3 other people completed this guide.
Kelsea Weber
21,491 Reputation
32 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 76
All Time: 21,631
