Tello Quadcopter Propeller Replacement
    1. Tello Quadcopter Propeller Replacement, Propeller: step 1, image 1 of 1
      • Identify the propeller being replaced.
      • Gather the required materials.
      Ask FixBot
    2. Tello Quadcopter Propeller Replacement: step 2, image 1 of 2 Tello Quadcopter Propeller Replacement: step 2, image 2 of 2
      • Next, remove the battery by grasping each side and pulling it out.
      Ask FixBot
    3. Tello Quadcopter Propeller Replacement: step 3, image 1 of 3 Tello Quadcopter Propeller Replacement: step 3, image 2 of 3 Tello Quadcopter Propeller Replacement: step 3, image 3 of 3
      • Remove the propeller by inserting the provided tool between the propeller and drone.
      • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
      • Gently lift the propeller from the socket using your choice of tool.
      Ask FixBot
    4. Tello Quadcopter Propeller Replacement: step 4, image 1 of 3 Tello Quadcopter Propeller Replacement: step 4, image 2 of 3 Tello Quadcopter Propeller Replacement: step 4, image 3 of 3
      • After removing the old propeller, orient the new propeller over the empty socket.
      • Insert a new propeller by applying force. The propeller should snap into place.
      Ask FixBot
You have successfully completed replacing the damaged propellor.
Cody White
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 2,858
