Tefal GV6760 Effectis Steam Generator Iron Disassembly
    1. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: step 1, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: step 1, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the base of the unit: step 1, image 3 of 3
      • This is the device we are going to teardown for repair. Other Tefal Steam irons may be similarly constructed.
      • When you remove the base the cord comes off and stays in the base. (photo two) Thus the difficult removal of the power cord is optional. If you wish to anyway, you can use a prying tool and remove it from base.
      • Use a Torx 20 bit to remove the four screws marked with red circles on the base.
      Ask FixBot
    2. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: step 2, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: step 2, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the connector to the handle: step 2, image 3 of 3
      • Once the base is off, we can see the inner workings of the iron. The steam generator unit is the large round steel vessel with the heating element and thermal safety sensors attached. This large steel part is now free. If the iron was used very recently, it may still be very hot, so be careful.
      • Remove the cord connector coming from the iron's handle by pulling it upwards. Remove the ground cable marked in the first photo (red circle) also.
      • Locate two plastic tabs that hold the upper cover inside the plastic casing. Second (gold rectangle) and third photos show openings through which you can reach the tabs.
      Ask FixBot
    3. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: step 3, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: step 3, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Release the tabs and remove top cover: step 3, image 3 of 3
      • The tab you need to pry is visible in the first photo. (The Blue plastic tab in the red rectangle)
      • The second photo shows the underside of the (base's) top cover. See the orange marked latching tabs on the top cover.
      • ATTENTION! Sometimes, there may be two additional screws holding the top cover to the blue plastic base. These screws are hidden under the rubber 'bumpers' (marked with green squares in the second photo). I think the screws were added during servicing wherein case tabs were broken. Possibly a clever provision on Tefal's side for repairability.
      Ask FixBot
    4. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove more cable connectors: step 4, image 1 of 2 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove more cable connectors: step 4, image 2 of 2
      • Now, we need to unplug these connectors to facilitate circuit board removal.
      Ask FixBot
    5. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: step 5, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: step 5, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the control panel: step 5, image 3 of 3
      • Locate the two tabs (red squares) that will enable you to remove the control panel.
      • Gently pry the tabs and the control panel will come free when you pull it forward.
      • Be careful! there are wires attached to the panel and not much slack.
      Ask FixBot
    6. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the screws of top decoration panel: step 6, image 1 of 2 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the screws of top decoration panel: step 6, image 2 of 2
      • There are three screws (circled in red in photos one and two) holding the top 'decorative' panel, use a Philips 0 bit to remove them.
      • Now the PCB can be seen, separated from the bottom part and held in place with tabs inside the top decoration.
      Ask FixBot
    7. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: step 7, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: step 7, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Remove the PCB from the top decoration: step 7, image 3 of 3
      • Pry the tabs (shown in red squares in the first and second photos) that hold the main PCB in place.
      • Remove the PCB.
      • The power button has a clear plastic insert; be careful not to lose it.
      Ask FixBot
    8. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Give that PCB a very good clean: step 8, image 1 of 2 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Give that PCB a very good clean: step 8, image 2 of 2
      • Even though the PCB has conformal coating; corrosion has somehow formed on it. I have seen this failure on two different irons. I think it must be a very common issue.
      • Use 99% isopropyl alcohol and a soft brush to clean the oxidation. In my case I had to use brake cleaner, too. I am not sure if this has damaged the existing conformal coating.
      • If you have 'paint on' conformal coating available, applying some may be a good idea. I haven't done it.
      • Use a hairdryer to dry the PCB before re-assembly.
      Ask FixBot
    9. Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: step 9, image 1 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: step 9, image 2 of 3 Tefal GV6760 Effectis Steam Generator Iron Disassembly, Put the steam generator iron back together: step 9, image 3 of 3
      • Do everything in reverse order to re-assemble the iron.
      • Make sure all connectors fit snugly.
      • Well-done. If the corrosion was not extensive and didn't 'eat' traces, your iron will work properly again. If there is further damage, I'm afraid you will need to repair or replace the board.
      Ask FixBot
10 other people completed this guide.
Koray
1,425 Reputation
5 Guides authored
4 Guide Comments
Very useful! I had no idea about how to remove the top cover.
Daniel-Mircea - Reply Share
Super! Vous avez expliqué ça très bien. Merci beaucoup 🥳
Mike Williams - Reply Share
Merci beaucoup. J'ai une centrale vapeur CALOR Effectis, model GV6820. Elle a une conception très très similaire et se démonte de la même façon. Pouvez-vous changer dans le titre du tutoriel "Tefal" par "Tefal ou Calor". Ce serait utile lors de la recherche. Merci.
Gilles Guérin - Reply Share
I have the same model of iron, and the water light flashes when there is water. Is this the problem? Is the machine new?
admin demo - Reply Share
Past 24 Hours: 11
Past 7 Days: 70
Past 30 Days: 306
All Time: 10,582
