Teenage Engineering OP-Z Rubber Feet Replacement
  1. Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: step 1, image 1 of 3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: step 1, image 2 of 3 Teenage Engineering OP-Z Rubber Feet Replacement, Back Cover: step 1, image 3 of 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
    Ask FixBot
  2. Teenage Engineering OP-Z Rubber Feet Replacement: step 2, image 1 of 2 Teenage Engineering OP-Z Rubber Feet Replacement: step 2, image 2 of 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
    Ask FixBot
  3. Teenage Engineering OP-Z Rubber Feet Replacement: step 3, image 1 of 1
    • Remove the bottom plate including the rubber feet.
    Ask FixBot
  4. Teenage Engineering OP-Z Rubber Feet Replacement, Rubber Feet: step 4, image 1 of 1
    • Remove the four Phillips #0 screws from the back of the rubber feet.
    Ask FixBot
  5. Teenage Engineering OP-Z Rubber Feet Replacement: step 5, image 1 of 2 Teenage Engineering OP-Z Rubber Feet Replacement: step 5, image 2 of 2
    • Separate the front and rear part of the rubber feet from the back cover.
    Ask FixBot
  6. Teenage Engineering OP-Z Rubber Feet Replacement: step 6, image 1 of 1
    • When reassembling make sure to correctly align the front and rear part of the rubber feet. The notch and grove should interlock and fit into the cutout of the back cover.
    Ask FixBot
Tobias Isakeit
134,246 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 2,340
