Teenage Engineering OP-Z Battery Replacement
    1. Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 1 of 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 2 of 3 Teenage Engineering OP-Z Battery Replacement, Back Cover: step 1, image 3 of 3
      • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
      • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
      Ask FixBot
    2. Teenage Engineering OP-Z Battery Replacement: step 2, image 1 of 2 Teenage Engineering OP-Z Battery Replacement: step 2, image 2 of 2
      • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
      • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
      Ask FixBot
    3. Teenage Engineering OP-Z Battery Replacement: step 3, image 1 of 1
      • Remove the bottom plate including the rubber feet.
      Ask FixBot
    1. Teenage Engineering OP-Z Battery Replacement, Battery: step 4, image 1 of 2 Teenage Engineering OP-Z Battery Replacement, Battery: step 4, image 2 of 2
      • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
      Ask FixBot
    2. Teenage Engineering OP-Z Battery Replacement: step 5, image 1 of 2 Teenage Engineering OP-Z Battery Replacement: step 5, image 2 of 2
      • Remove the battery.
      • When installing the new battery make sure you put it in contact side first.
      Ask FixBot
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
4 other people completed this guide.
Tobias Isakeit
135,275 Reputation
189 Guides authored
2 Guide Comments
Does anyone know if there a way to purchase this battery in Australia? the link for the battery above says not available in Australia.. Does anyone know of another source? thanks
richard - Reply Share
This article seems a bit pointless when you have stopped making the replacement batteries... Any chance you might restart?
Adrian Sell - Reply Share
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 136
All Time: 11,520
