Teenage Engineering OP-1 Connector Board Replacement
    1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: step 1, image 1 of 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: step 1, image 2 of 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: step 1, image 3 of 3
      • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
      • Lift the back panel and remove it. The Connector Board is revealed.
      Ask FixBot
    2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: step 2, image 1 of 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: step 2, image 2 of 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: step 2, image 3 of 3
      • Disconnect the flex connector by lifting it up with a spudger.
      • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
      • Take out the connector board.
      • Make sure to keep the black rubber pad underneath the board.
      Ask FixBot
    3. Teenage Engineering OP-1 Connector Board Replacement: step 3, image 1 of 2 Teenage Engineering OP-1 Connector Board Replacement: step 3, image 2 of 2
      • Don't forget the cover for the on/off switch.
      • Simply take it off from the old board and transfer it to the new board.
      Ask FixBot
48 other people completed this guide.
teenage engineering
1,131 Reputation
2 Guides authored
44 Guide Comments
Veeery useful , thank you !
mouchtouris alexandre - Reply Share
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - Reply Share
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J - Reply Share
Past 24 Hours: 9
Past 7 Days: 103
Past 30 Days: 308
All Time: 54,987
