Teddy Ruxpin Battery Replacement
Views: 4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
96
All Time:
3,973
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Teddy Ruxpin is not turning on you may need to replace the battery. This is a replacement guide for removing the batteries from the Teddy Ruxpin model #17262DS. For this guide, you will need four double AA batteries and a Phillips #2 screwdriver head. This replacement guide should be quick and easy.
Parts
Tools
    1. Teddy Ruxpin Battery Replacement, Battery: step 1, image 1 of 2 Teddy Ruxpin Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
      Ask FixBot
    2. Teddy Ruxpin Battery Replacement: step 2, image 1 of 1
      • Pull the tab outward to remove the protective plate for the batteries.
      Ask FixBot
    3. Teddy Ruxpin Battery Replacement: step 3, image 1 of 1
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
      Ask FixBot
2 other people completed this guide.
Lauren
226 Reputation
2 Guides authored
Cal Poly, Team S18-G5, White Winter 2020 Member of Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 96
All Time: 3,973
