Tecknet M003 Wireless Mouse Scroll Wheel Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
67
Past 30 Days:
241
All Time:
1,513
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
A defective wheel that won't scroll is a common issue among computer users, and those using the Tecknet wireless mouse (M003) are no exception. By following this guide, you will learn the steps to replacing the scrolling wheel in your Tecknet wireless mouse.
The process requires minimal technical ability: if you know how to use a screwdriver and change out batteries, you can easily come to know how to fix a stuck mouse wheel. You will begin by locating and removing three screws, then separating the case into two halves so you can work on the interior.
Replacing the wheel itself is almost as simple as pulling it out and pushing a new one in - but it may not even be necessary. Most mouse scrolling problems can be solved by simply cleaning the wheel or removing debris from the cradle. At step 5, you will have an opportunity to see if cleaning solves the issue. If it doesn't, proceed with step 6: replacing the wheel itself.
Before beginning the repair, make sure your device is powered off.
Tools
    1. Tecknet M003 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Tecknet M003 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
      • Turn the mouse over so the bottom is facing up.
      Ask FixBot
    2. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 2, image 1 of 2 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 2, image 2 of 2
      • Peel off the mouse feet to reveal the first two 9 mm Phillips #0 screws.
      Ask FixBot
    3. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 3, image 1 of 2 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 3, image 2 of 2
      • Remove battery cover to expose the battery compartment.
      • Remove the batteries.
      Ask FixBot
    4. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 4, image 1 of 3 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 4, image 2 of 3 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 4, image 3 of 3
      • Remove all three 9 mm Phillips #0 screws.
      Ask FixBot
    5. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 5, image 1 of 3 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 5, image 2 of 3 Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 5, image 3 of 3
      • Carefully separate the top and side panels from the bottom cover.
      • Put the bottom on a flat surface and set the top and side panels to the left of it.
      • Some guides recommend disconnecting the gray cables for more working space. For this model, it is not necessary—leave the cables connected.
      Ask FixBot
    6. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 6, image 1 of 1
      • Gently push the wheel left and right until you free its axle from the cradle's socket.
      • Once the axle is free, lift the wheel from the cradle and remove the defective scrolling wheel.
      Ask FixBot
    7. Tecknet M003 Wireless Mouse Scroll Wheel Replacement: step 7, image 1 of 1
      • Slide the notched axle end of the new wheel into the socket, then gently push the wheel down until it clicks into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Amanda M.
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 67
Past 30 Days: 241
All Time: 1,513
