Teac DC-D2831 Drive Belt replacement
    1. Teac DC-D2831 Drive Belt replacement, Drive Belt: step 1, image 1 of 2 Teac DC-D2831 Drive Belt replacement, Drive Belt: step 1, image 2 of 2
      • Separate the turntable from the top of the record player by lifting straight up.
      Ask FixBot
    2. Teac DC-D2831 Drive Belt replacement: step 2, image 1 of 1
      • Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
      • Do not stretch the belt too far as it may break.
      Ask FixBot
    3. Teac DC-D2831 Drive Belt replacement: step 3, image 1 of 3 Teac DC-D2831 Drive Belt replacement: step 3, image 2 of 3 Teac DC-D2831 Drive Belt replacement: step 3, image 3 of 3
      • Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
      • It may be helpful to lay the record player on its side to keep the belt wrapped around both the motor and the turntable wheel.
      Ask FixBot
    4. Teac DC-D2831 Drive Belt replacement: step 4, image 1 of 1
      • Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2 other people completed this guide.
Charles Lockner
118 Reputation
2 Guides authored
Cal Poly, Team 2-61, Propen Fall 2012 Member of Cal Poly, Team 2-61, Propen Fall 2012
CPSU-PROPEN-F12S2G61
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 44
All Time: 4,481
