Up to 20% off select tools
Tea Kettle Switch Replacement
Views: 29K
View statistics:
Past 24 Hours:
25
Past 7 Days:
93
Past 30 Days:
397
All Time:
28,999
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Tea Kettle Switch Replacement, Switch: step 1, image 1 of 3 Tea Kettle Switch Replacement, Switch: step 1, image 2 of 3 Tea Kettle Switch Replacement, Switch: step 1, image 3 of 3
      • Before you start, disconnect the device from its power source.
      • Remove the two bottom screws.
      • Remove the two top screws.
      • Remove the handle from the kettle.
      Ask FixBot
    2. Tea Kettle Switch Replacement: step 2, image 1 of 2 Tea Kettle Switch Replacement: step 2, image 2 of 2
      • Pull out the switch.
      • If you pull too hard, you may dislodge another part as well as the spring that are both positioned behind the switch.
      Ask FixBot
    3. Tea Kettle Switch Replacement: step 3, image 1 of 1
      • Click the replacement switch back into the handle part.
      Ask FixBot
    4. Tea Kettle Switch Replacement: step 4, image 1 of 1
      • Insert the light back into the switch.
      • This might take some extra attention, so be precise.
      Ask FixBot
    5. Tea Kettle Switch Replacement: step 5, image 1 of 1
      • Place the handle part back on the frame.
      Ask FixBot
    6. Tea Kettle Switch Replacement: step 6, image 1 of 1
      • Plug in the kettle.
      • Press down on the switch to check if it works again.
      Ask FixBot
7 other people completed this guide.
Author
with
Anniek Moll
245 Reputation
1 Guide authored
3 Guide Comments
How much would it cost to repair this kettle switch live points?
Bheki Valoyi - Reply Share
How much would it cost to fix the tea kettle switch live points?
Can the kettle gadgets be replaced with another one
Michael Ombech - Reply Share
Past 24 Hours: 25
Past 7 Days: 93
Past 30 Days: 397
All Time: 28,999
