Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement
    1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Back Cover: step 1, image 1 of 1
      • Remove the four Torx T5 screws from the back panel.
      Ask FixBot
    2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 2, image 1 of 1
      • Wedge a spudger in between the front and back panel.
      • Apply leverage downwards to the spudger in order to remove the back panel.
      Ask FixBot
    1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Battery: step 3, image 1 of 1
      • Slide the battery out from under the brown wire-tape.
      • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
      Ask FixBot
    2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
      Ask FixBot
    1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Motherboard: step 5, image 1 of 1
      • Unscrew the 2 Philips #00 screws on each end of the motherboard.
      Ask FixBot
    2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 6, image 1 of 1
      Buy
      • Pull off the black memory card slot piece with tweezers.
      Ask FixBot
    3. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 7, image 1 of 1
      • Unscrew the 2 Philips #00 screws on each side of the charging port.
      Ask FixBot
    4. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 8, image 1 of 2 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 8, image 2 of 2
      • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
      Ask FixBot
    5. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 9, image 1 of 1
      • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
      • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
      Ask FixBot
    6. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 10, image 1 of 1
      • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
      Ask FixBot
    7. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 11, image 1 of 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 11, image 2 of 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 11, image 3 of 3
      • Disconnect the large brown wire-tape from the motherboard.
      • Peel the black tape back from the wire-tape using tweezers.
      • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
      • The screen and motherboard components can now be separated from each other.
      Ask FixBot
    1. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement, Touchscreen/Display: step 12, image 1 of 1
      • Unscrew the 2 Philips #00 screws from the bottom edge of the screen component.
      Ask FixBot
    2. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 13, image 1 of 1
      • Take off the brown wire-tape from the small circuit board component.
      • Lift up so that the black plastic hinge piece swings open and the tape can be removed.
      Ask FixBot
    3. Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 14, image 1 of 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 14, image 2 of 3 Tapwave T2907US Zodiac 2 Touchscreen/Display Replacement: step 14, image 3 of 3
      • Warning: If you are too rough with the screwdriver, you can permanently damage the display.
      • Use a Slot SL1.5 screwdriver to pry the touchscreen shell from the display component using the 4 slots around the entire component
      Ask FixBot
Daniel Wiseman
133 Reputation
6 Guides authored
Cal Poly, Team 10-33, Amido Winter 2012 Member of Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 110
All Time: 1,611
