Tagital T9X Battery Replacement
  1. Tagital T9X Battery Replacement, Back Cover: step 1, image 1 of 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Battery Replacement: step 2, image 1 of 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Battery Replacement, Battery: step 3, image 1 of 1
    • Using a plastic spudger, carefully pry the battery from its position. Ensure that you do not puncture or bend the battery in this process.
    • The only wires for removal are the red and black wires that are soldered into the battery and motherboard.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 579
