Up to 20% off select tools
Table Lamp Cord Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
12
Past 7 Days:
112
Past 30 Days:
401
All Time:
9,455
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Parts
Tools
Introduction
Go to step 1 ↓
This step-by-step guide teaches the users two procedures: removing and replacing an old lamp cord and attaching a new cord to the socket.
    1. Table Lamp Cord Replacement, Cord: step 1, image 1 of 2 Table Lamp Cord Replacement, Cord: step 1, image 2 of 2
      • Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
      • The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
      Ask FixBot
    2. Table Lamp Cord Replacement: step 2, image 1 of 1
      • Caution! Before removing the lightbulb, ensure that the lamp is unplugged.
      • Cut the old lamp wire using scissors.
      • Remove the cord from the lamp.
      • Dispose the cord.
      Ask FixBot
    3. Table Lamp Cord Replacement: step 3, image 1 of 2 Table Lamp Cord Replacement: step 3, image 2 of 2
      • Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
      • Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
      Ask FixBot
    4. Table Lamp Cord Replacement: step 4, image 1 of 2 Table Lamp Cord Replacement: step 4, image 2 of 2
      • Place the lock nut at the end of the lamp nipple and turn it clockwise.
      • Thread the lock nut a quarter of the way through the lamp nipple.
      Ask FixBot
    5. Table Lamp Cord Replacement: step 5, image 1 of 2 Table Lamp Cord Replacement: step 5, image 2 of 2
      • Ensure that the lamp cord sticks through the top of the lamp base.
      • Insert the lamp nipple and the lock nut into the bottle, in such a way that one-fourth inch of the lamp nipple faces up.
      Ask FixBot
    6. Table Lamp Cord Replacement: step 6, image 1 of 1
      • Insert the socket in the lamp nipple.
      • Tighten the socket by turning it clockwise until it reaches the lock nut.
      Ask FixBot
    7. Table Lamp Cord Replacement: step 7, image 1 of 1
      • Pull either ends of the wire so that you have about 2-3 inches of the wire separated.
      Ask FixBot
    8. Table Lamp Cord Replacement: step 8, image 1 of 1
      • Tie an underwriter's knot in the two separated pieces of wire.
      • How to tie the knot: Form a loop using the first wire. Take the second wire and form a loop around the first. Pass the tail of the second wire through the loop of the first.
      Ask FixBot
    9. Table Lamp Cord Replacement: step 9, image 1 of 1
      • Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
      • Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
      Ask FixBot
    10. Table Lamp Cord Replacement: step 10, image 1 of 2 Table Lamp Cord Replacement: step 10, image 2 of 2
      • Place the socket shell (with paper liner) over the socket interior. Snap it into correct position. Listen for clicks to make sure that the shell is locked properly.
      • The socket should snap together to form one piece.
      Ask FixBot
    11. Table Lamp Cord Replacement: step 11, image 1 of 1
      • Caution: Be sure that the rewired lamp is not plugged at this step.
      • Insert the new light bulb into the socket. Plug the cord and turn it on.
      Ask FixBot
3 other people completed this guide.
Author
with
Aysha Vear
195 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 112
Past 30 Days: 401
All Time: 9,455
