Up to 20% off select tools
Table Lamp Bulb and Wiring Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
57
Past 30 Days:
230
All Time:
1,493
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Over time, table lamps can experience issues such as flickering bulbs, faulty wiring, or complete power failure. If your lamp is no longer functioning properly, replacing the bulb or rewiring the internal components can restore its usability. This step-by-step guide will walk you through the process of safely replacing a table lamp's bulb and wiring, ensuring your lamp is both functional and safe to use. Whether you're troubleshooting a non-working lamp or upgrading its components, this guide will help you complete the repair with confidence.
    1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: step 1, image 1 of 1
      • Switch off the lamp to ensure no electricity is flowing.
      • Unplug the lamp from the power outlet to prevent the risk of electric shock.
      • Wait a few minutes to allow any remaining electrical charge to dissipate.
      Ask FixBot
    2. Table Lamp Bulb and Wiring Replacement: step 2, image 1 of 1
      • Locate the screw at the base of the lamp that secures the light fixture to the structure.
      • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
      • Keep the screw in a secure place to avoid losing it during reassembly.
      Ask FixBot
    3. Table Lamp Bulb and Wiring Replacement: step 3, image 1 of 1
      • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
      • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
      Ask FixBot
    4. Table Lamp Bulb and Wiring Replacement: step 4, image 1 of 3 Table Lamp Bulb and Wiring Replacement: step 4, image 2 of 3 Table Lamp Bulb and Wiring Replacement: step 4, image 3 of 3
      • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
      • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
      Ask FixBot
    5. Table Lamp Bulb and Wiring Replacement: step 5, image 1 of 3 Table Lamp Bulb and Wiring Replacement: step 5, image 2 of 3 Table Lamp Bulb and Wiring Replacement: step 5, image 3 of 3
      • Take off the white cover from bottom to top.
      Ask FixBot
    6. Table Lamp Bulb and Wiring Replacement: step 6, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 6, image 2 of 2
      • Cut both of the old wires with wire cutters.
      Ask FixBot
    7. Table Lamp Bulb and Wiring Replacement: step 7, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 7, image 2 of 2
      • Take out the new wire and make sure lamp wires correlate to its terminal.
      • Neutral is marked blue, hot is marked red.
      Ask FixBot
    8. Table Lamp Bulb and Wiring Replacement: step 8, image 1 of 1
      • Thread the wire through the small hole under the lamp.
      Ask FixBot
    9. Table Lamp Bulb and Wiring Replacement: step 9, image 1 of 2 Table Lamp Bulb and Wiring Replacement: step 9, image 2 of 2
      • Secure the wires to the screws using a Phillips screwdriver.
      • Tighten the screws so that the wires are secured under the screws.
      Ask FixBot
    10. Table Lamp Bulb and Wiring Replacement: step 10, image 1 of 1
      • Use a Phillips screwdriver to screw the wire between its correlating screw.
      • Blue is neutral, red is hot.
      Ask FixBot
    11. Table Lamp Bulb and Wiring Replacement: step 11, image 1 of 1
      • Plug the lamp in, and the bulb will light up.
      Ask FixBot
Finish Line
Author
with
Jeffrey Cong
193 Reputation
1 Guide authored
UC Davis, Team 3-3, Andersen Winter 2025 Member of UC Davis, Team 3-3, Andersen Winter 2025
UCD-ANDERSEN-W25S3G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 57
Past 30 Days: 230
All Time: 1,493
