Up to 20% off select tools
Table Fan Blades Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
119
All Time:
3,114
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your 6-8 inch Personal Table Fan has been lagging or the blades have broke. Use this guide to replace the blades in your fan.
Before using this guide, make sure your fan works when plugged in. If it does not, the blades are not the issue, the motor is and this guide will not fix the issue.
Before beginning, make sure to unplug your fan.
    1. Table Fan Blades Replacement, Blades: step 1, image 1 of 3 Table Fan Blades Replacement, Blades: step 1, image 2 of 3 Table Fan Blades Replacement, Blades: step 1, image 3 of 3
      • Use a prying tool to loosen the front cover.
      • After it is pried loose, remove the cover.
      Ask FixBot
    2. Table Fan Blades Replacement: step 2, image 1 of 1
      • Remove two 12.7 mm Phillips #2 screws from the back cover.
      • Take off the back cover.
      Ask FixBot
    3. Table Fan Blades Replacement: step 3, image 1 of 1
      • Remove two 38.1 mm Phillips #2 screws from the motor.
      Ask FixBot
    4. Table Fan Blades Replacement: step 4, image 1 of 3 Table Fan Blades Replacement: step 4, image 2 of 3 Table Fan Blades Replacement: step 4, image 3 of 3
      • While holding the back of the fan, pull the blades.
      • Take off the old blades and put them aside.
      Ask FixBot
    5. Table Fan Blades Replacement: step 5, image 1 of 1
      • Take the motor out.
      Ask FixBot
    6. Table Fan Blades Replacement: step 6, image 1 of 2 Table Fan Blades Replacement: step 6, image 2 of 2
      • Clean all parts of the fan.
      Ask FixBot
    7. Table Fan Blades Replacement: step 7, image 1 of 2 Table Fan Blades Replacement: step 7, image 2 of 2
      • Put the motor and back cover back on.
      • This can be done by following steps 2, 3, and 5 in reverse.
      Ask FixBot
    8. Table Fan Blades Replacement: step 8, image 1 of 1
      • Place the new blade onto the metal rod on the front of the fan.
      • Push the blades onto the rod so that it is sturdy.
      • Replace the front cover.
      Ask FixBot
Finish Line
Author
with
Cora Diehl
178 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 119
All Time: 3,114
