This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows the steps for "TUXEDO InfinityBook Pro 14 Gen 6 replacement battery replacement".
Position the laptop so that you can read the label.
Release the seven screws. The screws at the bottom (6 and 7) are shorter.
Carefully lift off the back cover. If necessary, use an opening pick to gently release it all the way around.
Remove the screw (1).
Pry up the SSD at the right side by about 30° and carefully pull it out of the M.2 interface (2).
Carefully pry the connection cable out in the direction of the cable harness. It helps to use a spudger at the point with the white dot. Do not pull on the cables!
Release the four screws.
Remove the replacement battery
Reassembly in reverse order.
Follow the steps in reverse order to reassemble your device.
