TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
66
All Time:
2,122
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Remove bottom cover: step 1, image 1 of 1
      • Orient the laptop so that you can read the nameplate.
      • The front two screws (circled in red) are shorter than the remaining screws (circled in light green)
      Ask FixBot
    2. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Unplug the battery: step 2, image 3 of 3
      • To avoid damage, the battery should be disconnected
      • Carefully pull the plug out of the connector
      Ask FixBot
    3. TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 1 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 2 of 3 TUXEDO InfinityBook Pro 14 - Gen6 SSD Replacement, Replace SSD: step 3, image 3 of 3
      • The model has two M.2 NVMe slots
      • Red: PCIe 4.0 x4
      • Green: PCIe 3.0 x2
      • Remove the mounting screw
      • The SSD will then pop out of its anchorage
      • Then gently pull the SSD out of its slot
      Ask FixBot
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
[deleted]
272 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 66
All Time: 2,122
