TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement
    1. TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Detaching the keyboard and loosening the bottom cover: step 1, image 1 of 1
      • To remove the bottom cover, we must first remove all the screws that can be reached from below.
      • These are 10 marked in green. These connect the bottom cover plate to the top case
      • There are also 2 marked in blue. These connect the bottom cover to the keyboard assembly.
      • The keyboard can then be easily lifted through the opening (here yellow) using a blunt object.
      Ask FixBot
    2. TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Removing the keyboard: step 2, image 1 of 2 TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Removing the keyboard: step 2, image 2 of 2
      • By lifting the keyboard slightly from the underside, it can be reached from below.
      • The keyboard assembly has clips at the bottom that reach under the housing. These are only clamped on the other sides.
      • It can be lifted out of the housing step by step using a thin, stable object.
      Ask FixBot
    3. TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Remove the Bottom cover: step 3, image 1 of 2 TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Remove the Bottom cover: step 3, image 2 of 2
      • Once the keyboard is loose, we can remove 3 more screws.
      • Once these have been tightened, the bottom cover can be removed without any difficulty.
      Ask FixBot
    4. TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Replacing the hard disk: step 4, image 1 of 2 TUXEDO InfinityBook Pro 14 - Gen 5 Hard Disk Replacement, Replacing the hard disk: step 4, image 2 of 2
      • Without the bottom cover, the two hard disks (yellow) are easy to reach
      • In the example, the 2.5” Sata hard disk is missing, but the NVMe can be seen.
      • Other interesting components: RAM (blue), Wifi (orange), LTE (red).
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
ongy
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 74
All Time: 1,025
