Up to 20% off select tools
TRS-80 Color Computer Fuse Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
92
All Time:
3,756
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 40 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Replace a broken fuse on the TRS-80 Color Computer's power supply.
    1. TRS-80 Color Computer Fuse Replacement, Outside Casing: step 1, image 1 of 1
      • Flip the computer over.
      • Remove the two 24.1mm Phillips screws near the front of the case.
      • Remove the five 33.0 mm Phillips screws towards the back of the case.
      Ask FixBot
    2. TRS-80 Color Computer Fuse Replacement: step 2, image 1 of 2 TRS-80 Color Computer Fuse Replacement: step 2, image 2 of 2
      • Carefully flip the computer right side up.
      • Lift off the top half of the case.
      Ask FixBot
    1. TRS-80 Color Computer Fuse Replacement, Keyboard: step 3, image 1 of 2 TRS-80 Color Computer Fuse Replacement, Keyboard: step 3, image 2 of 2
      • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
      • Lift the keyboard out of the case.
      Ask FixBot
    1. TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 1 of 3 TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 2 of 3 TRS-80 Color Computer Fuse Replacement, Motherboard: step 4, image 3 of 3
      • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
      • When removing the spring door, make sure to keep the door closed.
      Ask FixBot
    2. TRS-80 Color Computer Fuse Replacement: step 5, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 5, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 5, image 3 of 3
      • Remove the 5 jumper cables from the motherboard.
      • Once the jumper cables lift the motherboard up gently; it should lift out easily.
      Ask FixBot
    1. TRS-80 Color Computer Fuse Replacement, Fuse: step 6, image 1 of 2 TRS-80 Color Computer Fuse Replacement, Fuse: step 6, image 2 of 2
      • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
      Ask FixBot
    2. TRS-80 Color Computer Fuse Replacement: step 7, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 7, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 7, image 3 of 3
      • Remove the power cable jumpers from the power supply.
      Ask FixBot
    3. TRS-80 Color Computer Fuse Replacement: step 8, image 1 of 1
      • Gently peel back the protective film on the top of the transformer.
      Ask FixBot
    4. TRS-80 Color Computer Fuse Replacement: step 9, image 1 of 3 TRS-80 Color Computer Fuse Replacement: step 9, image 2 of 3 TRS-80 Color Computer Fuse Replacement: step 9, image 3 of 3
      • Locate the two points the fuse is soldered into the circuit board.
      • Using a soldering iron and soldering wick, desolder and remove the fuse.
      • Place the new fuse into the location of the old one, and solder it in place.
      Ask FixBot
3 other people completed this guide.
Author
with
Christopher Paige
553 Reputation
3 Guides authored
Cal Poly, Team 11-24, Maness Winter 2011 Member of Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 92
All Time: 3,756
