Up to 20% off select tools
TOZO HT2 Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
109
All Time:
1,443
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
Every electronic device powered by batteries will eventually need a replacement, as batteries degrade over time with use. After a long time of use, the battery can begin to deteriorate losing functionality much like a phone after years of use. Symptoms of a deteriorating battery include shorter charge time, difficulty recharging, or complete failure. These are common signs of declining battery health. In this guide, we’ll walk you through replacing the battery located beneath the left ear pad. Be prepared to carefully navigate around the daughterboard during the replacement. Following these steps will ensure your device regains its optimal performance with a fully functional battery.
Each of the screws for this project are the same 6.3mm Phillips head screws.
    1. TOZO HT2 Battery Replacement, Ear Pad: step 1, image 1 of 3 TOZO HT2 Battery Replacement, Ear Pad: step 1, image 2 of 3 TOZO HT2 Battery Replacement, Ear Pad: step 1, image 3 of 3
      • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
      • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
      Ask FixBot
    2. TOZO HT2 Battery Replacement: step 2, image 1 of 3 TOZO HT2 Battery Replacement: step 2, image 2 of 3 TOZO HT2 Battery Replacement: step 2, image 3 of 3
      • Twist the ear cover counterclockwise until it pops off.
      • Repeat for the other ear pad if necessary.
      Ask FixBot
    1. TOZO HT2 Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the four Phillips screws securing the speaker housing.
      Ask FixBot
    2. TOZO HT2 Battery Replacement: step 4, image 1 of 1
      • Use a spudger to gently pry the battery out of its housing.
      • Do not use a metal spudger as demonstrated in the photo. Take care not to puncture or bend the battery.
      Ask FixBot
    3. TOZO HT2 Battery Replacement: step 5, image 1 of 1
      • Take wire cutters and carefully snip the battery free, cutting as close to the battery as possible.
      Ask FixBot
    4. TOZO HT2 Battery Replacement: step 6, image 1 of 1
      • Solder the wires onto the new battery.
      • HANDLE WITH CARE: Soldering iron can be VERY hot (reaching temperatures up to or above 400°C or 800°F).
      • Wear eye protection while soldering and only do so in a well ventilated area and/or with a fume extractor.
      • Remove all possible fire hazards from the surrounding area.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Raven M
605 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 109
All Time: 1,443
