TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement
  1. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Precautionary Measures: step 1, image 1 of 3 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Precautionary Measures: step 1, image 2 of 3 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Precautionary Measures: step 1, image 3 of 3
    • Remove spark plug wire and spark plug using a 5/8" socket to prevent accidental ignition of mower.
    Ask FixBot
  2. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 2, image 1 of 1
    • Prop up the rear end of the lawnmower using a jack stand, scissor jack, or some other stable platform. Both rear wheels should be off the ground.
    • Use 2 wedges/wood blocks to keep the front wheels stationary.
    Ask FixBot
  3. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Removing first wheel: step 3, image 1 of 1
    • Set tire-height adjustment lever to forward-most position (past "A").
    Ask FixBot
  4. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 4, image 1 of 1
    • Remove center nut from wheel using 9/16" socket.
    • If the nut is stuck, apply WD-40 to the site and wait a few minutes.
    Ask FixBot
  5. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 5, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 5, image 2 of 2
    • Remove the wheel, washer, and plastic cover.
    Ask FixBot
  6. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 6, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 6, image 2 of 2
    • Pry off the metal gear-retaining clip using a flathead screwdriver.
    • Remove gear.
    Ask FixBot
  7. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 7, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 7, image 2 of 2
    • Remove the snap ring using snap ring pliers.
    Ask FixBot
  8. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 8, image 1 of 1
    • Use a 1/2" socket wrench to remove the bolt holding the bearing assembly from the wheel.
    Ask FixBot
  9. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 9, image 1 of 1
    • Remove the wheel bearing.
    • A flathead screwdriver may help to pry off a stuck bearing.
    Ask FixBot
    • Refer to steps 3-9
    Ask FixBot
  10. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Removing the old transmission: step 11, image 1 of 1
    • Flip the lawnmower so that the underside is visible.
    • Ensure that the gas tank side is on the top.
    Ask FixBot
  11. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 12, image 1 of 1
    • Remove the drive belt from the two mounted locations at the transmission housing and engine shaft.
    Ask FixBot
  12. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 13, image 1 of 1
    • Disconnect transmission stabilizing spring.
    Ask FixBot
  13. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 14, image 1 of 1
    • Remove the plastic covers (3) from the transmission shaft.
    Ask FixBot
  14. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 15, image 1 of 1
    • Use a 3/8" socket wrench to remove the bolts from the supporting tab.
    Ask FixBot
  15. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 16, image 1 of 1
    • Remove the transmission from the underside of the lawnmower.
    Ask FixBot
  16. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 17, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 17, image 2 of 2
    • Remove the drive cable from the transmission housing.
    • Needle nose pliers may help in removing the drive cable.
    • Ensure that the large spring located on the right side of the picture is disconnected from the transmission housing as well.
    Ask FixBot
  17. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the new transmission: step 18, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the new transmission: step 18, image 2 of 2
    • Re-attach the drive cable at the cable mounting point of the new transmission.
    Ask FixBot
  18. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 19, image 1 of 1
    • Slide on the transmission support tab to the transmission shaft.
    • Slide transmission shaft back into slot.
    Ask FixBot
  19. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 20, image 1 of 1
    • Re-attach the springs to the transmission housing.
    Ask FixBot
  20. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 21, image 1 of 1
    • Use a 3/8" socket wrench to install the 2 bolts on the bearing support tab to the underside of the lawnmower.
    Ask FixBot
  21. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 22, image 1 of 1
    • Re-install the belt to the two mounting points.
    • Twisting the transmission housing counterclockwise will allow for the belt to stretch into position easier.
    Ask FixBot
  22. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 23, image 1 of 1
    • Re-attach the plastic covers (3) to the transmission shaft.
    Ask FixBot
  23. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the wheels: step 24, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the wheels: step 24, image 2 of 2
    • Flip the lawnmower back to its original position.
    • Place the scissor jack and wood blocks to support the lawnmower.
    Ask FixBot
  24. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Reattaching the Wheel: step 25, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Reattaching the Wheel: step 25, image 2 of 2
    • Re-install the wheel bearing and bolt on the right-side wheel using a 1/2" socket wrench.
    Ask FixBot
  25. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 26, image 1 of 1
    • Secure a clamp between the gold rod assembly and the mower sidewall to ensure that the components added next won't slide off.
    Ask FixBot
  26. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Reattaching the Wheel Continued: step 27, image 1 of 1
    • On the other side, re-install the height adjustment lever, wheel bearing, and bearing bolt using a 1/2" socket wrench.
    Ask FixBot
  27. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 28, image 1 of 1
    • Re-install the snap ring using a pair of snap ring pliers. There is a groove in the rod that the snap ring must fit around.
    Ask FixBot
  28. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 29, image 1 of 1
    • Re-install gear.
    Ask FixBot
  29. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 30, image 1 of 1
    • Use a flathead screwdriver to re-install the metal gear-retaining clip.
    Ask FixBot
  30. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 31, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 31, image 2 of 2
    • Re-install the wheel cover and the washer.
    Ask FixBot
  31. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 32, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 32, image 2 of 2
    • Re-install wheel and use a 9/16" socket wrench to re-attach the center nut.
    Ask FixBot
  32. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement: step 33, image 1 of 1
    • Return to the other side and remove the clamp.
    Ask FixBot
  33. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Reattaching the Second Wheel: step 34, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Reattaching the Second Wheel: step 34, image 2 of 2
    • Refer to Steps 25, 27-32
    Ask FixBot
  34. TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the spark plug: step 35, image 1 of 2 TORO 30" Personal Pace TimeMaster Mower Transmission Assembly Replacement, Installing the spark plug: step 35, image 2 of 2
    • Use a 5/8" socket wrench to re-install the spark plug.
    • Re-attach the spark plug cable.
    Ask FixBot
Finish Line
4 other people completed this guide.
Zachary Perry
729 Reputation
2 Guides authored
2 Guide Comments
Is there supposed to be a return spring on the other end of the lever that the traction cable attaches to?
Tom P - Reply Share
On mine, it was just throttle cable to transmission and belt drive. There are some return springs just to help stabilize the transmission housing (see steps 18-22)
Zachary Perry - Reply Share
Past 24 Hours: 2
Past 7 Days: 58
Past 30 Days: 216
All Time: 4,001
