TMY V08 Cooling Fan Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
84
All Time:
797
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If you need to replace the cooling fan in the TMY V08, the replacement process can be found in this guide. You may need this guide if the projector turns off unexpectedly while watching things for long periods of time, or makes a loud humming noise. If you have any of these issues, first reference to our Troubleshooting guide
Before beginning the replacement, make sure the TMY V08 is on a solid surface. Also make sure the TMY V08 is away from non-hardwood flooring and carpets. This will reduce the risk if static electric shocks that may damage the circuit or other components.
Tools
    1. TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 1 of 3 TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 2 of 3 TMY V08 Cooling Fan Replacement, Top Panel: step 1, image 3 of 3
      • Turn the projector upside-down.
      • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
      • Turn the projector back over and lift the top casing panel off the projector.
      Ask FixBot
    2. TMY V08 Cooling Fan Replacement: step 2, image 1 of 3 TMY V08 Cooling Fan Replacement: step 2, image 2 of 3 TMY V08 Cooling Fan Replacement: step 2, image 3 of 3
      • Pinch and pull the bundled cable connector from the top panel.
      • Remove the top panel from the projector.
      Ask FixBot
    1. TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 3 TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 3 TMY V08 Cooling Fan Replacement, Cooling Fan: step 3, image 3 of 3
      • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
      • Pull back the motherboard to expose the connectors underneath.
      Ask FixBot
    2. TMY V08 Cooling Fan Replacement: step 4, image 1 of 2 TMY V08 Cooling Fan Replacement: step 4, image 2 of 2
      • Rotate the projector counterclockwise 90 degrees.
      • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
      Ask FixBot
    3. TMY V08 Cooling Fan Replacement: step 5, image 1 of 3 TMY V08 Cooling Fan Replacement: step 5, image 2 of 3 TMY V08 Cooling Fan Replacement: step 5, image 3 of 3
      • Rotate the projector counter clockwise with the front facing you.
      • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
      • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
      Ask FixBot
    4. TMY V08 Cooling Fan Replacement: step 6, image 1 of 3 TMY V08 Cooling Fan Replacement: step 6, image 2 of 3 TMY V08 Cooling Fan Replacement: step 6, image 3 of 3
      • Remove the five 7.3 mm screws from the black cover using a Phillips #1 screwdriver.
      • Take off the right black cover, exposing the fan.
      Ask FixBot
    5. TMY V08 Cooling Fan Replacement: step 7, image 1 of 1
      • Firmly grasp and lift up the fan to remove it.
      Ask FixBot
2 Guide Comments
Question, great guide by the way, do you know the sizes of the fans inside this unit?
JTone - Reply Share
the reason i ask, i am pretty new to electronics repair but i wanted to see if there was a way i could get fan that run quieter in this unit.
JTone - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 84
All Time: 797
