TMY V08 Button Circuit Board Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
57
All Time:
454
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you need to replace the buttons in the TMY V08, the replacement process can be found in this guide. The buttons may need to be replaced if you click them and they don't perform the function they are supposed to do. If you need any additional help check out our Troubleshooting Guide.
In order to keep the motherboard safe, before beginning the replacement, make sure the TMY V08 is on a solid surface. Also make sure the TMY V08 is away from non-hardwood flooring and carpets. This will reduce the risk of static electric shocks that may damage the circuit or other components.
Tools
    1. TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 1 of 3 TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 2 of 3 TMY V08 Button Circuit Board Replacement, Top Panel: step 1, image 3 of 3
      • Turn the projector upside-down.
      • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
      • Turn the projector back over and lift the top casing panel off the projector.
      Ask FixBot
    2. TMY V08 Button Circuit Board Replacement: step 2, image 1 of 3 TMY V08 Button Circuit Board Replacement: step 2, image 2 of 3 TMY V08 Button Circuit Board Replacement: step 2, image 3 of 3
      • Pinch and pull the bundled cable connector from the top panel.
      • Remove the top panel from the projector.
      Ask FixBot
    1. TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 1 of 3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 2 of 3 TMY V08 Button Circuit Board Replacement, Button Circuit Board: step 3, image 3 of 3
      • Remove the four 4.8 mm screws from the button circuit board beneath the top cover using a Phillips #1 screwdriver.
      • Remove the button circuit board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 454
