Parts
Scooter Wheels (Eagle Supply)OptionalFor sale from another site
Depending if you need a wheel to replace one or two wheels from your scooter it is preferable to have wheels prebuilt with bearings already inserted.
Tools
TV Y-TOOL (The Vault)
If you're a scooter rider, the TV Y-Tool is a highly recommended tool to have in your toolkit. This multi-functional tool includes allen keys of sizes 4, 5, and 6, which can be used to loosen or tighten almost every bolt on your scooter.
Introduction
Go to step 1 ↓Replacing a wheel on a TILT pro scooter is a common maintenance task that any rider should know how to do. Whether you're upgrading your wheels or replacing a damaged one, it's important to know the steps to ensure a smooth and safe ride. In this guide, we'll take you through the necessary steps to replace a wheel on your pro scooter. You'll need a few tools and a bit of patience, but with this guide, you should be able to replace your wheel in no time.
Flip your scooter upside down where the handle bars and wheels touch the ground to prepare the extraction of the wheel.
To reassemble the wheel from the back of the scooter repeat step 1, follow the instructions similar to the front wheel.
