Up to 20% off select tools
TI-84 Plus Silver Edition Battery Spring Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
78
All Time:
1,557
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide is useful if the battery spring in your calculator has been broken and needs to be replaced. The only requirements are the tools needed to remove the screws, pry the calculator open, and remove and replace the battery spring. All of these tools can be purchased easily. The only hazards that might be seen are damaging the inside electronics of the calculator once it is open so it is best to leave the open calculator in a safe place.
    1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: step 1, image 1 of 2 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: step 1, image 2 of 2
      • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
      Ask FixBot
    2. TI-84 Plus Silver Edition Battery Spring Replacement: step 2, image 1 of 2 TI-84 Plus Silver Edition Battery Spring Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the calculator open.
      • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
      Ask FixBot
    3. TI-84 Plus Silver Edition Battery Spring Replacement: step 3, image 1 of 1
      • Remove the battery in order to access the battery spring that needs to be replaced.
      Ask FixBot
    4. TI-84 Plus Silver Edition Battery Spring Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the damaged spring using the tweezers.
      Ask FixBot
    5. TI-84 Plus Silver Edition Battery Spring Replacement: step 5, image 1 of 2 TI-84 Plus Silver Edition Battery Spring Replacement: step 5, image 2 of 2
      • Pick up the new spring with the tweezers.
      • Insert the new spring with the tweezers.
      • Gently push the new spring into place using your finger.
      Ask FixBot
    6. TI-84 Plus Silver Edition Battery Spring Replacement: step 6, image 1 of 1
      • Test by replacing the battery that was taken out to check the connection.
      Ask FixBot
Author
with
Clayton Rudolph
157 Reputation
1 Guide authored
2 Guide Comments
Hi! So where can I get the spring part?
Aleyson B.Hunter - Reply Share
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 78
All Time: 1,557
