TI-84 Plus Silver Edition Backup Battery Replacement
Views: 73K
View statistics:
Past 24 Hours:
6
Past 7 Days:
43
Past 30 Days:
248
All Time:
72,742
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows you how to replace the backup battery on the TI-84 Plus Silver Edition. The backup battery is located on the back side of the calculator above the main batteries.
Parts
Tools
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 1 of 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 2 of 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: step 1, image 3 of 3
      • Push firmly down on the tab located on the back of the calculator near the center.
      • Pull the tab up, lifting it off of the calculator and exposing the batteries.
      Ask FixBot
    2. TI-84 Plus Silver Edition Backup Battery Replacement: step 2, image 1 of 1
      • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
      • Push the positive (+) side of the batteries to remove them
      Ask FixBot
    1. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: step 3, image 1 of 1
      • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
      Ask FixBot
    2. TI-84 Plus Silver Edition Backup Battery Replacement: step 4, image 1 of 1
      • Grab the plate and lift gently upward, to remove the backup battery cover.
      Ask FixBot
    3. TI-84 Plus Silver Edition Backup Battery Replacement: step 5, image 1 of 2 TI-84 Plus Silver Edition Backup Battery Replacement: step 5, image 2 of 2
      • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
      • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
      • Push gently downward until the backup battery pops out.
      Ask FixBot
17 other people completed this guide.
Agustin
1,047 Reputation
2 Guides authored
Cal Poly, Team 11-34, Amido Fall 2013 Member of Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Members
72 Guides authored
9 Guide Comments
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Reply Share
Because it's a completely different calculator.
Ozan Munsuz - Reply Share
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Reply Share
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Reply Share
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel - Reply Share
Past 24 Hours: 6
Past 7 Days: 43
Past 30 Days: 248
All Time: 72,742
