Up to 20% off select tools
TI-84 Plus Disassembly
Views: 15K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
206
All Time:
14,672
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. TI-84 Plus Disassembly, flip: step 1, image 1 of 2 TI-84 Plus Disassembly, flip: step 1, image 2 of 2
      • Be sure the calculator is powered off before proceeding.
      • Take off the sliding cover, and flip your calculator to the back side.
      Ask FixBot
    2. TI-84 Plus Disassembly, battery plate.: step 2, image 1 of 2 TI-84 Plus Disassembly, battery plate.: step 2, image 2 of 2
      • Press down on the latch, then remove the battery cover.
      Ask FixBot
    3. TI-84 Plus Disassembly, take out the batteries: step 3, image 1 of 2 TI-84 Plus Disassembly, take out the batteries: step 3, image 2 of 2
      • Remove the batteries.
      • You can use the battery cover as a plate to keep the batteries.
      Ask FixBot
    4. TI-84 Plus Disassembly, back up battery: step 4, image 1 of 3 TI-84 Plus Disassembly, back up battery: step 4, image 2 of 3 TI-84 Plus Disassembly, back up battery: step 4, image 3 of 3
      • Removing this battery will clear your RAM, so be sure that you have made any backups of important data.
      • Use a Phillips #0 to remove the plate from the back up battery.
      Ask FixBot
    5. TI-84 Plus Disassembly, backup battery: step 5, image 1 of 2 TI-84 Plus Disassembly, backup battery: step 5, image 2 of 2
      • Remove the backup battery with either a screwdriver or the spudger.
      Ask FixBot
    6. TI-84 Plus Disassembly, Remove the back cover: step 6, image 1 of 1
      • Use a T6 Torx screwdriver to remove the six screws securing the back cover.
      Ask FixBot
    7. TI-84 Plus Disassembly, cracking the case: step 7, image 1 of 3 TI-84 Plus Disassembly, cracking the case: step 7, image 2 of 3 TI-84 Plus Disassembly, cracking the case: step 7, image 3 of 3
      • Use a prying tool to get a pick into the side and then move it down until it's open.
      Ask FixBot
12 other people completed this guide.
Author
with
martijn muntenaar
777 Reputation
1 Guide authored
1 Guide Comment
Nice! My calculator wasn't turning on, took it apart and rebent the contacts for the batteries, works great now!
Noah Molla - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 206
All Time: 14,672
