Up to 20% off select tools
TI-36X Pro Battery Replacement
Views: 38K
View statistics:
Past 24 Hours:
8
Past 7 Days:
45
Past 30 Days:
289
All Time:
38,288
Comments: 5
5 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
For this guide you will remove the back cover and battery cover in order to replace the battery.
    1. TI-36X Pro Battery Replacement, Back Cover: step 1, image 1 of 2 TI-36X Pro Battery Replacement, Back Cover: step 1, image 2 of 2
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      Ask FixBot
    2. TI-36X Pro Battery Replacement: step 2, image 1 of 2 TI-36X Pro Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      Ask FixBot
    1. TI-36X Pro Battery Replacement, Battery: step 3, image 1 of 2 TI-36X Pro Battery Replacement, Battery: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 7.5 mm screws holding the battery cover to the case.
      • Remove the battery cover without disconnecting either end of the blue wire.
      • Use your finger to move the battery cover to the side.
      Ask FixBot
    2. TI-36X Pro Battery Replacement: step 4, image 1 of 1
      • Use the flat side of a spudger to remove the battery by lifting the bottom edge.
      • When inserting a new battery, check the polarity (+ or -) and insert the new battery with the + side on top.
      Ask FixBot
11 other people completed this guide.
Author
with
Robert Sekerak
667 Reputation
4 Guides authored
Cal Poly, Team 11-52, Amido Spring 2014 Member of Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 Members
60 Guides authored
5 Guide Comments
Interesting that the cr2032 battery is not rechargeable, so is the solar panel real? Or does it bypass the battery and use the solar panel in lighted situations?
frogman896 - Reply Share
The guide should specify that the CR2032 needs to be rechargeable. They are readily available at a popular online shopping website. I was skeptical that the solar was real too, because of the frosted plastic placed over it. Based on the pictures in this teardown, and another video showing a red LED in the solar circuit, I conclude that the solar charging circuit is real.
Jacob Ertel - Reply Share
The manual doesn't specify a rechargeable battery. It just says a CR2032 Lithium battery. Unless all such batteries are rechargeable? I guess I'll find out since I just replaced the battery in mine and it's an Energizer CR2032, but it doesn't appear to say rechargeable anywhere on the packaging or the battery itself. I guess if it kills my calculator, it had a good run....
EDIT: The original battery that I took out of the calculator doesn't say rechargeable on it either.
Marc W - Reply Share
good guide, I'd just like to add that in my case I needed to press the "Reset" button for my calculator to start up again
Greg B - Reply Share
yeah but I have done that 3 times and now my calculator is officially announced dead....
Danielle Kennedy - Reply Share
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 289
All Time: 38,288
