TI-30-XB Battery Replacement
    1. TI-30-XB Battery Replacement, Open the device: step 1, image 1 of 2 TI-30-XB Battery Replacement, Open the device: step 1, image 2 of 2
      • Remove the 6 Phillips #0 screws on the back
      • Remove the back cover
      • Be very careful when removing the back cover as it is brittle. It is recommended to open from all four sides.
      Ask FixBot
    2. TI-30-XB Battery Replacement, Eject the battery: step 2, image 1 of 3 TI-30-XB Battery Replacement, Eject the battery: step 2, image 2 of 3 TI-30-XB Battery Replacement, Eject the battery: step 2, image 3 of 3
      • Remove the 2 long Phillips #0 screws holding the battery
      • Eject the battery
      Ask FixBot
    3. TI-30-XB Battery Replacement, Finish up: step 3, image 1 of 2 TI-30-XB Battery Replacement, Finish up: step 3, image 2 of 2
      • Place the new battery onto the metal prod of the battery slot
      • Screw the 2 long Phillips #0 screws onto the battery cover
      Ask FixBot
    4. TI-30-XB Battery Replacement: step 4, image 1 of 3 TI-30-XB Battery Replacement: step 4, image 2 of 3 TI-30-XB Battery Replacement: step 4, image 3 of 3
      • Put the back cover back on and screw the 6 Phillips #0 screws back onto the back cover
      Ask FixBot
8 other people completed this guide.
Jordan Dann
272 Reputation
1 Guide authored
1 Guide Comment
if the calculator won't work after changing the battery, press the reset button.
Floris Van Lierde - Reply Share
Past 24 Hours: 13
Past 7 Days: 105
Past 30 Days: 387
All Time: 27,995
