Up to 20% off select tools
TCL 30Z Screen Protector Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
12
Past 30 Days:
59
All Time:
640
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This will take you step-by-step through the process, regardless of whether your existing screen protector is damaged or scratched, or if you just want to change the look of your device. To guarantee a seamless and effective screen protector replacement, follow these instructions.
    1. TCL 30Z Screen Protector Replacement, Prepare Your Workspace: step 1, image 1 of 1
      • Begin by turning off your TCL 30Z and finding a clean, well-lit workspace. Gather all necessary tools and materials.
      Ask FixBot
    2. TCL 30Z Screen Protector Replacement, Remove the Old Screen Protector: step 2, image 1 of 1
      • Use a plastic pry tool to gently lift one corner of the existing screen protector. Gradually peel it off, applying slight pressure to release any adhesive. Note: Be careful not to damage the screen or any surrounding components during this process.
      Ask FixBot
    3. TCL 30Z Screen Protector Replacement, Clean the Screen: step 3, image 1 of 1
      Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • Wipe the screen with a microfiber cloth to remove any smudges or fingerprints. Use cleaning solution or isopropyl alcohol for stubborn stains. Ensure the screen is completely dry before proceeding.
      • Reminder: Take your time during this step to ensure a clean surface for the new screen protector.
      Ask FixBot
    4. TCL 30Z Screen Protector Replacement, Align the Replacement Screen Protector: step 4, image 1 of 1
      • Carefully align the new screen protector with the edges of the screen. Once aligned, use your fingers to gently press it onto the screen.
      • Caution: Avoid touching the adhesive side of the screen protector to prevent fingerprints or debris.
      Ask FixBot
    5. TCL 30Z Screen Protector Replacement, Smooth out Bubbles: step 5, image 1 of 1
      • If any air bubbles are present, use a plastic pry tool or your fingers to smooth them toward the edges. Work from the center to ensure a bubble-free application.
      • Note: Small bubbles may disappear over time, but larger ones may need additional attention.
      Ask FixBot
    6. TCL 30Z Screen Protector Replacement, Final Inspection: step 6, image 1 of 1
      • Inspect the screen for any remaining bubbles or dust particles. If necessary, use dust removal stickers to lift and remove particles. Ensure the screen protector is securely in place.
      • Reminder: Allow the device to rest undisturbed for a few hours to ensure optimal adhesion.
      Ask FixBot
To replace the screen protector of TCL 30Z, follow these instructions in their order.
Author
with
Timothy
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 59
All Time: 640
