Up to 20% off select tools
TCA Yoke Calibration
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
157
All Time:
2,131
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
How to re-calibrate the Yoke, in case the Pitch and Roll Axis, Mini-stick and/or throttle levers are not providing correct input
This calibration can be performed on PC and on Xbox.
      • If you have your Yoke plugged-in, then unplug it.
      Ask FixBot
      • Set the switch at the back of the Yoke to PC position.
      • If you are using Xbox, you still need to set the switch to PC position.
      • Don't forget to switch it back to Xbox, once you have completed this guide.
      Ask FixBot
      • Make sure that Roll and Pitch are at resting point.
      • Make sure the right mini-stick is at resting point.
      • Make sure that Throttles are in the middle
      • Throttles don't have to be in the exact middle.
      Ask FixBot
    1. TCA Yoke Calibration, Press and hold the indicated buttons: step 4, image 1 of 1
      • Press and hold the buttons highlighted in the image
      Ask FixBot
      • Connect the Yoke to USB port while holding the buttons.
      • Once the Xbox button starts flashing, release the buttons.
      Ask FixBot
    2. TCA Yoke Calibration, Press XBOX button: step 6, image 1 of 1
      • Press on the Xbox button.
      • It should start flashing faster.
      Ask FixBot
    3. TCA Yoke Calibration, Move the Yoke all the way to the right.: step 7, image 1 of 1
      • Move the Yoke to the right, until you reach maximum.
      • Return the Yoke to Center.
      • For better results, move it smoothly, without forcing.
      Ask FixBot
    4. TCA Yoke Calibration, Move the Yoke all the way to the left.: step 8, image 1 of 1
      • Move the Yoke to the left, until you reach maximum.
      Ask FixBot
    5. TCA Yoke Calibration, Push the Yoke forward: step 9, image 1 of 1
      • Push the Yoke forward, until you reach maximum.
      • Make sure to not accidentally move yoke Left or Right.
      Ask FixBot
    6. TCA Yoke Calibration, Pull the Yoke backwards: step 10, image 1 of 1
      • Pull the Yoke towards yourself, until you reach maximum.
      Ask FixBot
    7. TCA Yoke Calibration, Move the mini-stick to the right: step 11, image 1 of 1
      • Move the mini-stick to the right, until you reach maximum.
      • Return the mini-stick to Center.
      Ask FixBot
    8. TCA Yoke Calibration, Move the mini-stick to the left.: step 12, image 1 of 1
      • Move the mini-stick to the left, until you reach maximum.
      Ask FixBot
    9. TCA Yoke Calibration, Move the mini-stick up: step 13, image 1 of 1
      • Move the mini-stick up, until you reach maximum.
      Ask FixBot
    10. TCA Yoke Calibration, Move mini-stick down: step 14, image 1 of 1
      • Move the mini-stick down, until you reach maximum.
      Ask FixBot
    11. TCA Yoke Calibration, Move both Throttles down: step 15, image 1 of 1
      • Move both throttles down, until you reach maximum.
      Ask FixBot
    12. TCA Yoke Calibration, Move throttles up: step 16, image 1 of 1
      • Move both throttles up, until you reach maximum.
      Ask FixBot
    13. TCA Yoke Calibration, Press XBOX button: step 17, image 1 of 1
      • Press Xbox button to finish the calibration.
      • Xbox button should stop flashing.
      • Make sure that Yoke, Throttles and mini-sticks have been returned to neutral positions.
      Ask FixBot
Finish Line
Author
with
Formica Fusca
2,626 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 157
All Time: 2,131
