Up to 20% off select tools
TCA Quadrant Calibration
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
118
All Time:
1,034
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
How to re-calibrate the levers of the Quadrant, in case they are not aligned or not providing correct input in the Flight Simulator.
      • If you have your Quadrant plugged-in, then unplug it.
      Ask FixBot
    1. TCA Quadrant Calibration, Lower all levers: step 2, image 1 of 2 TCA Quadrant Calibration, Lower all levers: step 2, image 2 of 2
      • Mover each of the 3 levers to the lowest position.
      Ask FixBot
    2. TCA Quadrant Calibration, Press and Hold the Indicated button.: step 3, image 1 of 1
      • Press and hold the button highlighted.
      Ask FixBot
    3. TCA Quadrant Calibration, Plug to USB port While holding the button.: step 4, image 1 of 1
      • Connect your Quadrant to USB port while still holding the button.
      • Once connected, wait a few seconds and let go of the button
      • You can connect to:
      • USB port of your PC.
      • USB Port at the back of your TCA Yoke.
      • USB port of your Xbox.
      • Do not use USB Hubs or extension cables.
      Ask FixBot
    4. TCA Quadrant Calibration, Move all levers up: step 5, image 1 of 2 TCA Quadrant Calibration, Move all levers up: step 5, image 2 of 2
      • Pull each levers to the highest position.
      • Move the levers smoothly for better calibration.
      Ask FixBot
    5. TCA Quadrant Calibration, Press the Indicated buttons: step 6, image 1 of 1
      • Press these 2 buttons at the same time.
      • This should save the calibration.
      Ask FixBot
Finish Line
Author
with
Formica Fusca
2,626 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 118
All Time: 1,034
