Up to 20% off select tools
TCA PRC 152A Disassembly
Views: 5.9K
View statistics:
Past 24 Hours:
9
Past 7 Days:
44
Past 30 Days:
208
All Time:
5,924
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This tutorial will explain how to completely disassemble the TCA PRC 152A radio and accessories.
Disclaimer : Disconnect all peripherals before disassembling.
    1. TCA PRC 152A Disassembly, Prepare the radio for dissasembly: step 1, image 1 of 1
      • Remove antenna and battery before dissasembly
      • Prepare the tools before starting We'll start with the radio and then the accessories...
      Ask FixBot
    2. TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 1 of 3 TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 2 of 3 TCA PRC 152A Disassembly, Removing the backpannel: step 2, image 3 of 3
      • Remove 4 screws on the backpannel
      • Phillips PH3
      • The small retention piece is held by the screw. Be careful not to lose the spring
      Ask FixBot
    3. TCA PRC 152A Disassembly, Removing the backpanel: step 3, image 1 of 2 TCA PRC 152A Disassembly, Removing the backpanel: step 3, image 2 of 2
      • Carefully open the rear panel with the opener's plastic tool.
      • You can see the connection map of the different terminals.
      • GPS option (Does not work)
      • PTT and config button socket
      • U283 6PIN connector
      • ON/OFF/Volume knob
      • Side connector (Does not work)
      Ask FixBot
    4. TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 1 of 3 TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 2 of 3 TCA PRC 152A Disassembly, Removing frontpannel: step 4, image 3 of 3
      • Carefully open the front panel with the opener's plastic tool.
      • Microphone attached to the PCB board (1.080KOhm).Can be replaced by POW-2744P-B-R
      • Speaker FCE 16Ohm 1Watt.
      • Beware of silicone for the sealing of the elements.
      Ask FixBot
    5. TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 1 of 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 2 of 3 TCA PRC 152A Disassembly, Frontpannel microphone removal: step 5, image 3 of 3
      • Remove 1 screw
      • Phillips PH1
      • Carefully remove withe the plastic tool
      Ask FixBot
    6. TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 1 of 3 TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 2 of 3 TCA PRC 152A Disassembly, Display and keyboard front card: step 6, image 3 of 3
      • Remove 4 screws
      • Phillips PH2
      • Disconnect the flat connector
      • Use caution when you remove the flat connector
      Ask FixBot
    7. TCA PRC 152A Disassembly, Display and keyboard front card: step 7, image 1 of 2 TCA PRC 152A Disassembly, Display and keyboard front card: step 7, image 2 of 2
      • Place the electronics elements on ESD bags
      Ask FixBot
    8. TCA PRC 152A Disassembly, Peripheral back card: step 8, image 1 of 3 TCA PRC 152A Disassembly, Peripheral back card: step 8, image 2 of 3 TCA PRC 152A Disassembly, Peripheral back card: step 8, image 3 of 3
      • Disconnect 2 JSP connectors and 2 flat connector
      • Remove 4 screws
      • Phillips PH2
      • Carefully disconect the connectors and the board
      Ask FixBot
    9. TCA PRC 152A Disassembly, Mainboard removal: step 9, image 1 of 3 TCA PRC 152A Disassembly, Mainboard removal: step 9, image 2 of 3 TCA PRC 152A Disassembly, Mainboard removal: step 9, image 3 of 3
      • Remove 4 screws
      • Phillips PH2
      • Disconnect the antenna connector
      • Carefully removing the mainboard
      • Thermal paste between the card and the body
      Ask FixBot
    10. TCA PRC 152A Disassembly, Side connectors removal: step 10, image 1 of 2 TCA PRC 152A Disassembly, Side connectors removal: step 10, image 2 of 2
      • Remove 2 screws
      • Phillips PH1
      • Carefully removing the connector
      Ask FixBot
    11. TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 1 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 2 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 11, image 3 of 3
      • Remove 2 screws
      • Phillips PH3
      • Remove the topcover, take care about short circuit
      Ask FixBot
    12. TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 1 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 2 of 3 TCA PRC 152A Disassembly, Batterybloc dissasembly: step 12, image 3 of 3
      • Remove battery stick (18650 Panasonic)
      • Remove 2 screws
      • Phillips PH3
      • Take off the inner white retainer
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Tomazo_88
479 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 44
Past 30 Days: 208
All Time: 5,924
