Introduction
Go to step 1 ↓In this guide, we will go into detail about how to disassemble the Sony TC-FX170 player and replace the worn belt within the player.
A worn belt that is not replaced with time will cause problems within the device such as issues rewinding, pausing, or fast-forwarding your video content.
Before beginning, make sure the device is shut down completely and disconnected from a power outlet.
Parts
Tools
Remove the two sets of screws from both sides of the unit (four in total) using the Phillips #0 screwdriver.
Grasp the outer sheath from the bottom at the rear of the unit. Pull the sides gently outwards and lift, pivoting the panel off the front bezel of the deck.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to wrap the replacement belt over the large end of the black wheel.
Orient the motor such that the solder joints hang over the rear of the cassette mechanism, hold the replacement belt back with tweezers and slide the motor back into place on top of it. Slowly slide the belt back toward the motor, aligning the belt to the motor's spindle.
To reassemble your device, follow the remaining steps in reverse order.
