Türlitoaster 77356 Switch Replacement
    1. Türlitoaster 77356 Switch Replacement, Switch: step 1, image 1 of 3 Türlitoaster 77356 Switch Replacement, Switch: step 1, image 2 of 3 Türlitoaster 77356 Switch Replacement, Switch: step 1, image 3 of 3
      • First unplug the toaster. Unscrew the toaster on the underside. 2 of the 4 screws are secured with a 3-sided screw 2.3.
      Ask FixBot
    2. Türlitoaster 77356 Switch Replacement: step 2, image 1 of 3 Türlitoaster 77356 Switch Replacement: step 2, image 2 of 3 Türlitoaster 77356 Switch Replacement: step 2, image 3 of 3
      • Loosen 6 Phillips screws to access the switch.
      • The switch can now be desoldered and replaced by e.g. this PWL-2P1TL-6SASHA power switch, pressure switch 250 V/AC 6 A 2 from Conrad. But the nose must be shortened
      Ask FixBot
    3. Türlitoaster 77356 Switch Replacement: step 3, image 1 of 3 Türlitoaster 77356 Switch Replacement: step 3, image 2 of 3 Türlitoaster 77356 Switch Replacement: step 3, image 3 of 3
      • I did not want to wait for the switch and tried to open the old switch.
      • For this you have to carefully bend open the 4 metal clips. On the back side melt or break the welded white pin.
      • On the photo you can see the slide that closes the two contacts left and right. On the photo the slide is inserted wrongly by me.
      • You can see that one side is charred and the slide is melted. This meant that the contact could no longer close tightly and had a loose contact.
      • With a heated screwdriver I was able to shape the slide back to shape. I cleaned the contacts with contact spray and "impregnated" them with Balistol.Then reassembled and bent the metal clips back.
      • Assembly in reverse order.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Andreas Reheis
4,119 Reputation
27 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,002
