Syntus ST150 Ultrasonic Plate Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
102
All Time:
1,933
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
An ultrasonic plate in an essential oil diffuser is an electric component that vibrates at a very fast rate, creates a mist with water and essential oils, and disperses the mist into the air. A typical ultrasonic plate lasts around 5000 hours, but when it is damaged it has to be replaced. This guide will show you how to disassemble and replace the ultrasonic plate of your Syntus Ultrasonic Diffuser model number ST150.
Before beginning the repair, be sure to unplug the power adapter.
Tools
    1. Syntus ST150 Ultrasonic Plate Replacement, Ultrasonic Plate: step 1, image 1 of 1
      • First, make sure the water tank inside the diffuser is completely dry to avoid any water from contacting the internal components.
      • Make sure the diffuser is disconnected from the power source to avoid electrical hazards.
      Ask FixBot
    2. Syntus ST150 Ultrasonic Plate Replacement: step 2, image 1 of 2 Syntus ST150 Ultrasonic Plate Replacement: step 2, image 2 of 2
      • With a Phillips #1 screwdriver, remove the three 10 mm screws on the bottom of the diffuser.
      Ask FixBot
    3. Syntus ST150 Ultrasonic Plate Replacement: step 3, image 1 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 3, image 2 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 3, image 3 of 3
      • Lift the water tank while holding the base of the diffuser.
      • Disconnect the three cables form the board.
      • Make sure when reassembling the diffuser to plug in each cable to its assigned port.
      Ask FixBot
    4. Syntus ST150 Ultrasonic Plate Replacement: step 4, image 1 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 4, image 2 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 4, image 3 of 3
      • To separate the board from the water tank, unscrew the three Phillips #1 10 mm screws securing the board.
      Ask FixBot
    5. Syntus ST150 Ultrasonic Plate Replacement: step 5, image 1 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 5, image 2 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 5, image 3 of 3
      • With a Phillips #0 screwdriver, remove the three 7 mm screws from the ultrasonic sensor cover.
      • Remove the cover to expose the ultrasonic sensor.
      Ask FixBot
    6. Syntus ST150 Ultrasonic Plate Replacement: step 6, image 1 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 6, image 2 of 3 Syntus ST150 Ultrasonic Plate Replacement: step 6, image 3 of 3
      • Detach the ultrasonic sensor from the water tank.
      • Detach the ultrasonic sensor connector from the board.
      Ask FixBot
    7. Syntus ST150 Ultrasonic Plate Replacement: step 7, image 1 of 1
      • Remove the rubber cover from the ultrasonic plate.
      Ask FixBot
    8. Syntus ST150 Ultrasonic Plate Replacement: step 8, image 1 of 1
      • Now you can replace the ultrasonic plate of your diffuser.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 102
All Time: 1,933
