Up to 20% off select tools
Syma X12S Motor Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
122
All Time:
1,298
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Syma X12S Motor Replacement, Syma X12S Motor: step 1, image 1 of 2 Syma X12S Motor Replacement, Syma X12S Motor: step 1, image 2 of 2
      • Before disassembling the quadcopter, find out which motor(s) need to be replaced.
      • Rotate your quadcopter until the front of the quadcopter is facing you, or the side opposite of the charger hole.
      • Remember where the motor(s) that needs replacement in relativity to the charger port.
      Ask FixBot
    2. Syma X12S Motor Replacement: step 2, image 1 of 3 Syma X12S Motor Replacement: step 2, image 2 of 3 Syma X12S Motor Replacement: step 2, image 3 of 3
      • Once you have designated broken motor take of all propellers in a pulling twisting motion.
      • Keep in mind you need to know at all times which motor is broken. You will need to know the position of the broken motor at various times during this project.
      Ask FixBot
    3. Syma X12S Motor Replacement: step 3, image 1 of 3 Syma X12S Motor Replacement: step 3, image 2 of 3 Syma X12S Motor Replacement: step 3, image 3 of 3
      • After all propellers are off the quadcopter flip the quadcopter over and unscrew the undercarriage from the body to reveal circuitboard and motors.
      • For this step you will need to have a small Phillips head screwdriver.
      Ask FixBot
      • Remove the motor shell and body cover from the four motors revealing circuitboard and the motors compleatly.
      • After separate these parts this makes it easier to reconstruct the quadcopter.
      Ask FixBot
2 other people completed this guide.
Author
with
Zack Azevedo
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 122
All Time: 1,298
