Introduction
These days disposing of things that do not work in the house is more common than trying to repair them. I believe people should learn how to fix things before they spend more money on another product. Today I will revive and restore the Swiffer WetJet, this guide will help anyone with a broken Swiffer to change the motor in order for it to work again.
Remove the cleaning solution, batteries and the battery container.
Use a Phillips #1 screwdriver to remove the screw (1.4x6.0mm) at the bottom of the WetJet.
Remove two more screws (1.4x5.0mm) in the interior where the cleaning solution is placed.
3 other people completed this guide.
4 Guide Comments
Thanks for the guide! I was able to replace the motor in our Swiffer with a spare mini "370" pump motor that happened to have an identical motor section once the pump was taken apart. Refer to my Imgur gallery for more info on disassembly.
The motor I used was "DC 3V-5V 3.7V Micro 370 Motor Mini Air Pump Vacuum Pump Self-Priming Pump" something like this motor.
Imgur Gallery: imgur.com/a/YQ5SvgG
Thank you! You're resources were invaluable. I've been trying to fix things since I got pregnant. A weird existential nesting. I finally have a success! Thanks to you. I am not handy but %#*!^@ I fixed our 5 year old swiffer wet jet.
I need a link to a replacement motor.
