Up to 20% off select tools
Sweatpants Drawstring Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
10
Past 7 Days:
72
Past 30 Days:
288
All Time:
6,408
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Sweatpants repair is a relatively easy task for most people to accomplish. This repair will take about 5 minutes. There are no immediate risks with this procedure, however, we can suggest a low risk of jabbing oneself with the blunt end of the drawstring threader. The tools required for this procedure include a pair of sweatpants, a drawstring, and a drawstring threader.
    1. Sweatpants Drawstring Replacement, Drawstring: step 1, image 1 of 1
      Ask FixBot
    2. Sweatpants Drawstring Replacement: step 2, image 1 of 3 Sweatpants Drawstring Replacement: step 2, image 2 of 3 Sweatpants Drawstring Replacement: step 2, image 3 of 3
      • Insert the blunt end of the Drawstring Threader in the hole of the sweatpants.
      Ask FixBot
    3. Sweatpants Drawstring Replacement: step 3, image 1 of 1
      • Push the Drawstring Threader through the hole and fabric of the sweatpants.
      • Use your hand to pull the fabric and push the Drawstring Threader simultaneously.
      Ask FixBot
    4. Sweatpants Drawstring Replacement: step 4, image 1 of 1
      • Gather the fabric together to move the Drawstring Threader through the hollow band of the sweatpants.
      Ask FixBot
    5. Sweatpants Drawstring Replacement: step 5, image 1 of 1
      • Push and pull the blunt end of the Drawstring Threader through the second hole of the sweatpants.
      Ask FixBot
    6. Sweatpants Drawstring Replacement: step 6, image 1 of 2 Sweatpants Drawstring Replacement: step 6, image 2 of 2
      • Pull the blunt side of the Drawstring Threader.
      • Pull the threader until the drawstring and the Threader have emerged through the second hole.
      • Keep pulling until the threader is removed from the sweatpants.
      Ask FixBot
    7. Sweatpants Drawstring Replacement: step 7, image 1 of 1
      • Remove the drawstring from the Drawstring Threader.
      Ask FixBot
    8. Sweatpants Drawstring Replacement: step 8, image 1 of 1
      • Hold the top of the sweatpants fabric.
      • Pull the drawstrings to match in equal length.
      Ask FixBot
    9. Sweatpants Drawstring Replacement: step 9, image 1 of 1
      • Tie the drawstrings together in a bow.
      • Tying the drawstrings will prevent another occurrence.
      Ask FixBot
Finish Line
Author
with
Sarah Zickert
210 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 72
Past 30 Days: 288
All Time: 6,408
