Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: step 1, image 1 of 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: step 1, image 2 of 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: step 1, image 3 of 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
    Ask FixBot
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: step 2, image 1 of 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
    Ask FixBot
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: step 3, image 1 of 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
    Ask FixBot
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: step 4, image 1 of 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: step 4, image 2 of 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: step 4, image 3 of 3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
    Ask FixBot
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: step 5, image 1 of 1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
    Ask FixBot
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: step 6, image 1 of 1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 801
