Swann Wi-Fi Indoor Security Camera Infrared LED Replacement
  1. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: step 1, image 1 of 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: step 1, image 2 of 3 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Case: step 1, image 3 of 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
    Ask FixBot
  2. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: step 2, image 1 of 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
    Ask FixBot
  3. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: step 3, image 1 of 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
    Ask FixBot
  4. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement, Infrared LED: step 4, image 1 of 1
    • Facing the inside of the front case, unscrew the three 2.0 mm Phillips #0 black screws located on the back of the LED ring.
    Ask FixBot
  5. Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: step 5, image 1 of 2 Swann Wi-Fi Indoor Security Camera Infrared LED Replacement: step 5, image 2 of 2
    • Release the clip connection connecting the LED ring to the motherboard.
    • Remove the infrared LED assembly.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 1,763
