Swann Doorphone Video Intercom Doorbell Replacement
    1. Swann Doorphone Video Intercom Doorbell Replacement, Camera: step 1, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement, Camera: step 1, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement, Camera: step 1, image 3 of 3
      • Flip the outdoor camera over so that the underside is facing up.
      • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
      Ask FixBot
    2. Swann Doorphone Video Intercom Doorbell Replacement: step 2, image 1 of 2 Swann Doorphone Video Intercom Doorbell Replacement: step 2, image 2 of 2
      • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
      • While pressing the gray square button, remove the blue wire from the first opening under the button.
      • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
      Ask FixBot
    3. Swann Doorphone Video Intercom Doorbell Replacement: step 3, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 3, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 3, image 3 of 3
      • Remove the other wires using the same steps as the blue wire.
      • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
      • Remove the back plate by pulling the plate away from the device.
      Ask FixBot
    4. Swann Doorphone Video Intercom Doorbell Replacement: step 4, image 1 of 2 Swann Doorphone Video Intercom Doorbell Replacement: step 4, image 2 of 2
      • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
      Ask FixBot
    5. Swann Doorphone Video Intercom Doorbell Replacement: step 5, image 1 of 2 Swann Doorphone Video Intercom Doorbell Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
      • Pull slowly in the direction of the cables until the connector is no longer attached.
      Ask FixBot
    6. Swann Doorphone Video Intercom Doorbell Replacement: step 6, image 1 of 2 Swann Doorphone Video Intercom Doorbell Replacement: step 6, image 2 of 2
      • Remove the camera from the device.
      Ask FixBot
    1. Swann Doorphone Video Intercom Doorbell Replacement, Doorbell: step 7, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement, Doorbell: step 7, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement, Doorbell: step 7, image 3 of 3
      • Using your fingers, take hold of the wire connector attached to the main board
      • Pull slowly towards your body until the connector is no longer attached.
      Ask FixBot
    2. Swann Doorphone Video Intercom Doorbell Replacement: step 8, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 8, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 8, image 3 of 3
      • Using the JIS #0 screwdriver, remove the 2 mm screws diagonal from each other from the main board.
      Ask FixBot
    3. Swann Doorphone Video Intercom Doorbell Replacement: step 9, image 1 of 2 Swann Doorphone Video Intercom Doorbell Replacement: step 9, image 2 of 2
      • Gently pull the main board away from the inside of the device and leave to the side.
      • The main board will still be attached to the device by a remaining set of wires, but do not need to be removed.
      Ask FixBot
    4. Swann Doorphone Video Intercom Doorbell Replacement: step 10, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 10, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 10, image 3 of 3
      • Using the JIS #0 screwdriver, remove the 1mm screws from each side of the doorbell spring-loaded cover-plate
      • While removing the second screw, hold down the cover-plate with your index finger to prevent the plate from springing out.
      Ask FixBot
    5. Swann Doorphone Video Intercom Doorbell Replacement: step 11, image 1 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 11, image 2 of 3 Swann Doorphone Video Intercom Doorbell Replacement: step 11, image 3 of 3
      • Remove the black circular doorbell cover-plate.
      • Remove the metal circular doorbell button.
      Ask FixBot
Joseph Kelemen
227 Reputation
1 Guide authored
USF Tampa, Team S2-G4, Eyestone Spring 2018 Member of USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Members
15 Guides authored
1 Guide Comment
Thanks for posting. It is great to find new sources of doorbell replacement information.
Jeselle Arce - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,875
