Swann Doorphone Video Intercom Camera Replacement
    1. Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 1 of 3 Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 2 of 3 Swann Doorphone Video Intercom Camera Replacement, Camera: step 1, image 3 of 3
      • Flip the outdoor camera over so that the underside is facing up.
      • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
      Ask FixBot
    2. Swann Doorphone Video Intercom Camera Replacement: step 2, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 2, image 2 of 2
      • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
      • While pressing the gray square button, remove the blue wire from the first opening under the button.
      • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
      Ask FixBot
    3. Swann Doorphone Video Intercom Camera Replacement: step 3, image 1 of 3 Swann Doorphone Video Intercom Camera Replacement: step 3, image 2 of 3 Swann Doorphone Video Intercom Camera Replacement: step 3, image 3 of 3
      • Remove the other wires using the same steps as the blue wire.
      • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
      • Remove the back plate by pulling the plate away from the device.
      Ask FixBot
    4. Swann Doorphone Video Intercom Camera Replacement: step 4, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 4, image 2 of 2
      • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
      Ask FixBot
    5. Swann Doorphone Video Intercom Camera Replacement: step 5, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
      • Pull slowly in the direction of the cables until the connector is no longer attached.
      Ask FixBot
    6. Swann Doorphone Video Intercom Camera Replacement: step 6, image 1 of 2 Swann Doorphone Video Intercom Camera Replacement: step 6, image 2 of 2
      • Remove the camera from the device.
      Ask FixBot
Emily Stenke
555 Reputation
4 Guides authored
USF Tampa, Team S2-G4, Eyestone Spring 2018 Member of USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Members
60 Guides authored
15 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 1,320
