Swagtron T3 Wheel Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
98
All Time:
4,897
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Replace one of your Swagtron's wheels with this guide. To avoid electric shock, discharge the capacitors using the capacitor discharge tool before making any changes to your Swagtron.
Tools
    1. Swagtron T3 Wheel Replacement, Cover: step 1, image 1 of 2 Swagtron T3 Wheel Replacement, Cover: step 1, image 2 of 2
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      Ask FixBot
    2. Swagtron T3 Wheel Replacement: step 2, image 1 of 3 Swagtron T3 Wheel Replacement: step 2, image 2 of 3 Swagtron T3 Wheel Replacement: step 2, image 3 of 3
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      Ask FixBot
    1. Swagtron T3 Wheel Replacement, Wheel: step 3, image 1 of 1
      • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
      • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
      Ask FixBot
    2. Swagtron T3 Wheel Replacement: step 4, image 1 of 2 Swagtron T3 Wheel Replacement: step 4, image 2 of 2
      • Pull the wheel off of its base.
      • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
      Ask FixBot
Klara Perkins
412 Reputation
2 Guides authored
Cal Poly, Team S13-G3, Forte Spring 2017 Member of Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 Members
48 Guides authored
3 Guide Comments
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - Reply Share
Can't the wheel off
Christopher Primo - Reply Share
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 98
All Time: 4,897
