Up to 20% off select tools
SwagTron T1 Outer Shell Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
95
All Time:
2,793
Comments: 11
7 comments on steps, 4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the outer shell of your SwagTron T1
    1. SwagTron T1 Outer Shell Replacement, Back Panels: step 1, image 1 of 1
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      Ask FixBot
    2. SwagTron T1 Outer Shell Replacement: step 2, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 2, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 2, image 3 of 3
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      Ask FixBot
    3. SwagTron T1 Outer Shell Replacement: step 3, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 3, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 3, image 3 of 3
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      Ask FixBot
    1. SwagTron T1 Outer Shell Replacement, Outer Shell: step 4, image 1 of 2 SwagTron T1 Outer Shell Replacement, Outer Shell: step 4, image 2 of 2
      • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
      • These screws will be low into the SwagTron.
      Ask FixBot
    2. SwagTron T1 Outer Shell Replacement: step 5, image 1 of 1
      • Turn the SwagTron right side up and slightly lift up the panel.
      • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
      Ask FixBot
    3. SwagTron T1 Outer Shell Replacement: step 6, image 1 of 3 SwagTron T1 Outer Shell Replacement: step 6, image 2 of 3 SwagTron T1 Outer Shell Replacement: step 6, image 3 of 3
      • Turn the SwagTron over and disconnect the wires from the motherboard.
      • Follow the wires to the underside of the SwagTron.
      • Carefully remove the cord and the panel together.
      • All the panels are now free from the SwagTron.
      Ask FixBot
Author
with
Gloria Whang
185 Reputation
1 Guide authored
Cal Poly, Team S17-G5, Banghart Spring 2017 Member of Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Members
60 Guides authored
4 Guide Comments
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - Reply Share
Where can I buy a Swagtron T1 replacement shell?
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig - Reply Share
Amazon.com Keyword: CertiCable
Jesse Griffis - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 95
All Time: 2,793
