SwagTron T1 Back Panels Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,195
Comments: 7
7 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This explains what will be necessary to not only replace the back panels, but also open the SwagTron T1 to have access to other parts.
Tools
    1. SwagTron T1 Back Panels Replacement, Back Panels: step 1, image 1 of 1
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      Ask FixBot
    2. SwagTron T1 Back Panels Replacement: step 2, image 1 of 3 SwagTron T1 Back Panels Replacement: step 2, image 2 of 3 SwagTron T1 Back Panels Replacement: step 2, image 3 of 3
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      Ask FixBot
    3. SwagTron T1 Back Panels Replacement: step 3, image 1 of 3 SwagTron T1 Back Panels Replacement: step 3, image 2 of 3 SwagTron T1 Back Panels Replacement: step 3, image 3 of 3
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      Ask FixBot
Adrian Abarca
384 Reputation
2 Guides authored
Cal Poly, Team S17-G5, Banghart Spring 2017 Member of Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,195
