Up to 20% off select tools
Surface Studio Power Supply Unit Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
120
All Time:
5,681
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace your power supply unit
    1. Surface Studio Power Supply Unit Replacement, Power Supply Unit: step 1, image 1 of 3 Surface Studio Power Supply Unit Replacement, Power Supply Unit: step 1, image 2 of 3 Surface Studio Power Supply Unit Replacement, Power Supply Unit: step 1, image 3 of 3
      • Lay the Surface face down on a padded surface
      • Be careful not to scratch the screen when laying it face down
      • Remove the four rubber feet at each corner concealing the Torx screws
      • Remove the four Torx screws under the rubber feet.
      • Two screws on the upper corners are longer than two screws on the lower corners.
      • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
      Ask FixBot
    2. Surface Studio Power Supply Unit Replacement: step 2, image 1 of 2 Surface Studio Power Supply Unit Replacement: step 2, image 2 of 2
      • Remove five torx screws holding the two fans to the midframe
      • Remove the two fans
      • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
      • Four large torx screws and four small torx screws hold the midframe to the upper frame.
      • Remove four large torx screws holding the midframe
      • Remove four small torx screws holding the midframe
      Ask FixBot
    3. Surface Studio Power Supply Unit Replacement: step 3, image 1 of 1
      • Slowly remove the midframe
      • Be careful: the speaker on the midframe is still attached to the motherboard
      • Detach the connectors for the two fans and the speaker
      Ask FixBot
    4. Surface Studio Power Supply Unit Replacement: step 4, image 1 of 3 Surface Studio Power Supply Unit Replacement: step 4, image 2 of 3 Surface Studio Power Supply Unit Replacement: step 4, image 3 of 3
      • A screw retaining the power supply is under the hard drive so both the hard drive and the heat sink assembly must be removed
      • Remove four spring loaded torx screw labeled 1 to 4
      • Remove four torx screw labeled 5 to 7
      • Remove 5mm hex mounting post
      • Use a spudger to remove the heatsink assembly from the motherboard
      Ask FixBot
    5. Surface Studio Power Supply Unit Replacement: step 5, image 1 of 2 Surface Studio Power Supply Unit Replacement: step 5, image 2 of 2
      • Remove three torx screws holding the hard drive brackets
      • Remove the hard drive and disconnect the SATA/SATA power cable
      Ask FixBot
    6. Surface Studio Power Supply Unit Replacement: step 6, image 1 of 2 Surface Studio Power Supply Unit Replacement: step 6, image 2 of 2
      • Remove a Phillips screw still retaining the power supply
      • Remove a torx screw retaining the power supply cable
      • Unplug the power supply from the motherboard
      • Lift the power supply up and away from the base unit
      Ask FixBot
5 other people completed this guide.
Author
with
The Raptor
6,415 Reputation
6 Guides authored
3 Guide Comments
Does anyone have a source for a new power supply?
AustinMike - Reply Share
Still no source fora power supply huh?
Steve - Reply Share
I recently purchased a MS Surface Studio 6th Generation computer and it seems that the USB ports don’t work properly and the headphone jack is dead…. Any ideas what I need to do to fix it before I send it back?
reowens - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 120
All Time: 5,681
